Just got some 255/50's and I have noticed that they do break a bit around hard turns and I can even spin them off the line, more than my 235's??? IS it just me or do these things like to make noise and not leave marks? I usually will spin for like 10 feet off the line but when i go bak over the same spot ther are no marks? these tires are like 3 days old, am I just wearing off the "new tire stuff" and will they begin to get a bit more sticky as time goes on?? I kinda like the way they squeal around turns, but hopefully its not destroying my tires, doesnt loo like it. So the question out of all this? Will they get more grippy? or do i need to heat them up alot before i race??
Kumho questions...
Yeah, I didn't like mine at first until I did a 150 round trip on the highway. Maybe it was less. Now I love them. Big difference from when I first left the tireshop that mounted them. Hadn't tried to launch in them yet, because of new gears getting broke in.
All should be ready now. [img]graemlins/evilgrin.gif[/img]<b>1998 Firebird 3800 Series II, A4</b><br />Direct-Flo Lid,K&N Filter,DEE TB Spacer,TPS-TEC,ZZP Mini-AFC,Raised and Cutout Airbox 7mm,BMR STB & Boxed LCAs,KYB AGX Shocks,Drilled/Slotted Rotors,180* Thermo,2.5\" Catco Cat,Dynomax 2.75\" custom catback,Kumho Ecstas/245,Jet Stage 2,3.42,Edge Racing 2870 Stall,B&M Tranny Cooler,B&M Deep Tranny Pan,LSD,AAM Girdle,1LE DS,NX Wet Kit,MSD DIS-4,MSD Blaster Coil Packs,Taylor Spiro Pro 8mm Wires,NGK TR6\'S gapped .045,ZZP UD WP Pulley,SLP Fan Switch,TT II\'s<br />N/A: 15.6342 @ 88.44 (On stock converter. Strugglin\' to beat it.)<br />Nitrous 50 Shot: 14.7463 @ 93.49
Yeah, after about 500 miles, they're totally awesome tires! Don't expect to be leaving 25 foot tire marks like you could with your Goodyears; these things hook up very quickly.Edward D.<br />1997 Firebird A4 - Black Metallic<br />SLP CAI, Decoma 3\" Catback<br />BMR SFCs, 1LE sway bars<br />some other stuff
