I got new 245/50ZR-16's. What's the proper tire inflation recommended? Discount tire put them 36 psi. What I know for 235's or less is 30 psi.
Michelins Pilot AS
Re: Michelins Pilot AS
I usually put mine at 35 PSI. So they were close. Side of the tire will have max of like 40-44 PSI.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Originally posted by ssms5411 View PostI usually put mine at 35 PSI. So they were close. Side of the tire will have max of like 40-44 PSI.Camaro99\'3.8, original spoil package (no body mods...PROUDLY), K&N, Lid 3800II, SLP CAI, Flowmaster, Z28Chrome Tips, 180* Thermostat.
PSI is how much air is in the tire and shows the max it can go to, I believe it stands for Pounds per square inch, as in how much air inside the tire.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Originally posted by ssms5411 View PostPSI is how much air is in the tire and shows the max it can go to, I believe it stands for Pounds per square inch, as in how much air inside the tire.Camaro99\'3.8, original spoil package (no body mods...PROUDLY), K&N, Lid 3800II, SLP CAI, Flowmaster, Z28Chrome Tips, 180* Thermostat.
yes the number on the side of the tire is the max psi that tire can handle. the number on the inside of the drivers door is the proper psi for your car. i run my 245 wide tires at 40psi to help the side wall a bit cause i enjoy taking the corners faster than i really need to.
Originally posted by madforce10 View Postyes the number on the side of the tire is the max psi that tire can handle. the number on the inside of the drivers door is the proper psi for your car. i run my 245 wide tires at 40psi to help the side wall a bit cause i enjoy taking the corners faster than i really need to.
Originally posted by 96blackmaro View PostThats the opposite of what you want to be doing there guy, at 40 psi the tires aren't going to making good contact with the road. It will be worse when they warm up, and your also going to replacing your tires much sooner. All your doing is bulging out the center of your tread.:slap: I guarantee if you lower the psi your car will grip better.
