can anybody tell me how to get gorilla wheel locks off with out the key????????
gorilla wheel locks
gorilla wheel locks
98 camaro 3.8 (THE PUNISHER)<p>JET STAGE II/B&M SHIFT PLUS/TAYLOR WIRES/SLP LOUDMOUTH w-3\" s- pipe/SLP CAI/SS MESH GRILLE/160 STAT/DERALE OIL COOLER<br />FLEXALITE TRANS COOLER/ 3.42-ZEXEL-TORSEN/KONIG MONSOON & KUHMO TIRES/MANUAL FAN SWITCH/1le sway bars & poly/KYB AGX SHOCKS/H&R SPRINGS/LS1 ALUMINUM DRIVE SHAFT/rk sport headers<p>WAITING FOR INSTALL:ssm heads,cam,3 angle valves/trans go shift kitTags: None
Grab one of your cheap sockets that is just a little bit smaller than the lug nut. Then grab a hammer and pound the socket onto the nut, then remove.
There is another long shot. Junk yards, at least around here, have buckets and buckets of locking lug wrenches. Maybe, just maybe, you could find one that would fit.
Or you could just go buy a new set. Good Luck.<a href=\"http://www.fatninjas.com/camaro\" target=\"_blank\">\'96 Camaro Convertible</a>
