I installed my sub frame connectors last week and here is a write up on how to do it to a 93-97 camaro convertible (98-02 differ a bit which will be explained later)
PASSENGERS SIDE-
1. So first disconnect negative battery cable because their will be welding involved and you dont want to fry your wiring or mess up the pcm.
2. Jack up drivers side and put on a jack (High enough for someone to get under and weld the sub frame connectors on).
3. Try to lift the car so that the rear tire does not come of the ground and put wedges on both sides of the tire so that the rear end end will not move or sway.
4. Take out the bolt that i needed to do the sub frame connector install. (Is right under the rear quarter panel in front of the rear tire).
5. Slide sub frame connector in place and put the bolt back and tighten as much as possible while holding the sub frame connector up against the frame with a jack.
6. Weld the front mount.
PASSENGERS SIDE-
