<blockquote>quote:</font><hr>Originally posted by TheCardinal: GM Parts direct
front sway bar, rear sway bar, insulators for each, 4 endlinks, shipped to your door, $193.55.
26032907 (1) This is the front sway bar.
10021221 (1) This is the rear sway bar.
10235886 (2) I'm guessing this is the bushing that holds the sway bar in place.
10288551 (2) Same for this one.
10221779 (4) These are the endlinks.
Now, what size bolts do I need? And, where do I get the metal brakets that go around the bushings that hold the sway bar in place?
You can re-use the brackets that go around the isolation bushings on the sway bar. They will fit just fine. Also have a couple of 13mm ratchet/socket combos handy...at least for the newer models this is what you needed for the entire sway bar removal & replacement.
2001 Onyx Black Camaro M5-Totalled<br />2005 Ford F150 XLT 5.4L<br /><br />\"To make peace, prepare for war.\"
In the rear you'll have to buy a U-bolt. I think it's 2.25". But you'll still have to reuse the middle piece as I haven't found one wide enough to contact the whole bushing.
Has anyone used zzp gt1 cam if so is it worth the money and time
