I have Raybestos 50,000 mile semi metallic pads up front and stock rotors. The raybestos pads squeal like hell. the rotors were turned when the pads were put on(about 7K mi ago). and they haev squealed since i got em. I took it back to the shop and the tech there said our cars are bad about caliper wear and that its the piston in the caliper and not the pad. I then asked everal other ppl and found this to apparently be BS cus none of them knew anything about that problem after only 87K miles...?
Any suggestions?
-Matt<br />Manager/Tech Support<br />Precision Speed & High Performance<br /><br />visit us on the web at:<br /><a href=\"http://www.precisionspeedonline.net\" target=\"_blank\">www.precisionspeedonline.net</a>
2 days ago
