would a 275/40/17 tire on 17'' rim fit under my car? Im not sure what is the widest tire that will fit
What is the widest tire that can fit on an 01
Re: What is the widest tire that can fit on an 01
Yes a 275 will fit. That's a normal size for 17's. The widest I know of in back would be a 315. That would require a lot of bfh mod. I have 295's out back and they required some bfh and I cut out bump stops.#1:1999 pewter metallic y87 rs A4 camaro.check out the pics on the link below<br />#2:Bright red 1979 Pontiac Trans Am. Brand new 400 cubic inch Pontiac Motor. All work done by me, except the engine work.<br /> <a href=\"http://www.cardomain.com/ride/2216133\" target=\"_blank\">http://www.cardomain.com/ride/2216133</a>
All these answers are correct. You can go larger than 315 out back if you b or mini tub but there's honestly no reason for it because I doubt you make enough power to require it. But yeah for a 17x9 wheel id go 275's. If you had a 10-11 inch wheel id do 295. Just my. 02.#1:1999 pewter metallic y87 rs A4 camaro.check out the pics on the link below<br />#2:Bright red 1979 Pontiac Trans Am. Brand new 400 cubic inch Pontiac Motor. All work done by me, except the engine work.<br /> <a href=\"http://www.cardomain.com/ride/2216133\" target=\"_blank\">http://www.cardomain.com/ride/2216133</a>
Originally posted by insidethreat07 View PostWhat would be the next size wider than 275? I love how the wide tires look on the camaros08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
