What is the widest tire that can fit on an 01 - FirebirdV6.com/CamaroV6.com Message Board
  • What is the widest tire that can fit on an 01
    would a 275/40/17 tire on 17'' rim fit under my car? Im not sure what is the widest tire that will fit
    Re: What is the widest tire that can fit on an 01
    Yes a 275 will fit. That's a normal size for 17's. The widest I know of in back would be a 315. That would require a lot of bfh mod. I have 295's out back and they required some bfh and I cut out bump stops.
    #1:1999 pewter metallic y87 rs A4 camaro.check out the pics on the link below<br />#2:Bright red 1979 Pontiac Trans Am. Brand new 400 cubic inch Pontiac Motor. All work done by me, except the engine work.<br /> <a href=\"http://www.cardomain.com/ride/2216133\" target=\"_blank\">http://www.cardomain.com/ride/2216133</a>
      I have seen mini tubed cars running 345s and some without out them running 335s.
        o ok thanks for all the info, never been good with tire sizes
          I would stick with the 275s though as there are no real issues with install.
            good deal
              Also depends on the wheel backspacing.
                All these answers are correct. You can go larger than 315 out back if you b or mini tub but there's honestly no reason for it because I doubt you make enough power to require it. But yeah for a 17x9 wheel id go 275's. If you had a 10-11 inch wheel id do 295. Just my. 02.
                  Ive seen people fit 315sm with no modification. Others, needed allot (PHB, BFH) depends no the car really.
                    What would be the next size wider than 275? I love how the wide tires look on the camaros
                      They make a 285/40R17. Its approx 26" in diameter which is fine.
                        The next size up would be a 285. Tires run in 10 mm increments. As for the size I think most still run a 285/40r17.
                          You can go 285 on the front, with a 17x9.5" rim.
                            so would 285s on the front and rear work on 17" 10 spoke ss rims? Im not sure how wide those rims are
                              i think the rims i want are 17x9
                              • Andy H
                                Transmission removal help!!
                                by Andy H
                              • 2.8 Bird
                                Abs inop
                                by 2.8 Bird
                              • fishin
                                by fishin
