so does a 5 speed have traction control,i was looking around my radio and found i have the plug in for the switch.
traction control switch
Re: traction control switch
Negative. All you have is a sensor in the rear, it just turns the "low trac" light on, in the gauge cluster when it senses low traction. All 97+ Camaros have the spot for the switch but not all came with the actual traction control system.3M MAFIA
________
take apart the dash, just pulling out my radio and some stuff under the steering column, i found 4 or 5 unused connectors. Im guessing, ASR, SGS, probably some other crap. you dont need TCS, you need better tires.
I have the TCS, its garbage. It does not control traction, it simply cuts fuel when it senses a slip. This is not helpful while driving in any condition, it results in major over corrections where finesse is required. Think of it of as trying to make deli thin slices of lunchmeat with a log splitter. Its just a ridiculous ham-fisted excuse for traction control. I'd always turn it off if it didnt turn on the dash light.
