ok i searched a little to decide whether or not to buy and adjustable or non. Ofcourse i read that it is reccommended that you get an adjustable one if you lower your car. but i also found someone that said...
You don't need an adj. rod unless you plan on running larger tires or drag radials. Hope this helps.
So what is valid info and what isnt?
Do you need an adjustable PHR if you lower your car or can you get by with a non adjustable one?
I plan on lowering my car, but i dont plan on running drag radials.
Thanks
2003 Chrome Silver Nissan 350z 6 Speed<br /><br />2001 Bright Rally Red Camaro 3800 M5-----SOLD but missed
As with all suspension mods, it helps a great deal if you understand what's going on, instead of taking some unknowns word from the Web, which is often downright dangerous.
[Preachy mode off]
The Panhard is attached to your rear axle at one end and your chassis at the other. Stock, it is roughly paralell to the ground. Lower the car and the two mounting points move a bit farther apart. So the constant length Panhard pulls the body a bit off center to the axle. This can cause tires to rub.
Because your Panhard is now at an angle to the ground, it also cranks a bit of "wedge" into your car. That means it will handle a bit differently in right and left handers. The adjustable Panhatd can center the body and fix the rub. It does nothing for the wedge.
Panhard relocation brackets may be able to fix the wedge. Is that important? Beats me.
There are also angle considerations for your LCAs, and relocation brackets for those also.
Lowering a car is really a messy thing with regard to suspension geometry.
