front end poppingand steering wheel off center after new TRE's and alignment - FirebirdV6.com/CamaroV6.com Message Board
  • front end poppingand steering wheel off center after new TRE's and alignment
    new duralast outer tie rod ends and alignment installed/done.... alignment was perfect. 3 days later i hear a pop at full lock going down my steep drive way.... sounds like a TRE pop. and then my steering wheel is off center. the center of the wheel has to be pointed at 10 to go straight.... ripped everything apart. the tie rod ends still seem good the inners seem good... HOWEVER, the castle nuts were both finger loose on the outer TRE's the hole for the cotter pin is about an 1/8 higher than the nut sits. i think the nut backed off before the alignment. and the steering wheel got off because the TRE shifted.... i've sold myself on that being what happened......i was gonna put washers underneath the nut to fix that problem.
    now, if you're still with me, my question is... after i tightened the castle nuts and there was no play. took it for a drive and the toe was still off. and i heard the same TRE popping noise at full lock.... could that be because the toe is off??????? like it was overextending on one side?
    also don't think its ball joints i checked to see if there was back and forth play with my tires holding/pushing @ 6 and 12
    Re: front end poppingand steering wheel off center after new TRE's and alignment
    I would say it could be because one side is off, only way to see is a allignment and try it afterwatds. If it stll does it something is def. wrong somewhere.
      im gonna take it into goodyear gemini where the alignment was done.. talked to my friend up there today... really annoyed with the situation not the shop, just the parts and the problem. . don't think i'll ever cheap out on tie rod ends again.
        installed washers last night, basically about an 1/8" spacer. and they redid the alignment for me today. everythings good now.
