The tires I have right now are P245s, the look sooo sweet, and I wanna get new tires soon, does the factory 235/255s look any different? maybe not as wide or something, their cheaper, but if they look alittle smaller in width, then I'm going with the 245s, I measured the tread and I think I got around 9 to 9.5 inches across on 16x8 rims. Thanks
p245 or p235/255??
My personal opinion is stay with the 245's. I have 255's right now and the look is night and day. The wider tires is probably one of the best looking things on my car but it's something that you can't really put your finger on unless you knew what it looked like before. Look around and see what prices you can find on 255's. Mine were basically the same price as if I wanted 235's because the 255 isn't something they really keep in stock and chances are if they have a couple around they've been there for a while. Just my opinion though.1998 Red RS 3.8l A4<br /> Whisper - K&N - N20 - 1LE Panhard - Ghetto STB - 255/50ZR16 Ecsta<br /> Removed grille - Limo tint - blackouts - A-pillar cf a/f ratio<br /> Panasonic DF88 - 1 12\" Eclipse 88120.4 - Eclipse 3322 amp<p><a href=\"http://members.cardomain.com/raven_rs\" target=\"_blank\">http://members.cardomain.com/raven_rs</a>
Go over to tirerack.com and do a search for 255/50/r16 tires
Plenty of brands. Heard good things about kumhos, and those will be the tires I replace my stock ones with (z rated or better to keep them soft).
Later.2001 75th Anniversary V6 Pewter Firebird w/ Chrome Wheels, T-Tops, & Y87<br />Mods: Free Ram Air, !Silencer, Holley Filter, Full 3\" Hooker Catback, 3\" Cat<br />Best time: 15.095 at 90.00 MPH with a 2.127 60\'
I had 235/55/16s on my Camaro, went to BF Goodrich Comp T/A HR4 255/50/16s. They were about $110 each. I've seen them listed as high as $125 each. Tirerack.com has the best online price that I found for them. And, like raven1469 said, if you don't get them on the internet, most places will have to order them, because they're an oddball size. Do keep in mind, though, that 255/50s will be taller than your 245/50s. Goodyear and BF Goodrich (And I'd imagine most other tire companies) list the specs for their tires, including height, so you can find a width and ratio that will provide a height that closely matches your 245s.Wife and a dog, they both think they\'re Kujo.<br /> <br />1999 3.8 A4 Y87<br />Navy Blue Metallic<br />BFG G-Force KDWS 275/40/17s, <br />WS6 Wheels (17x9)<br />Phoenix Transmissions 2400 Stall Converter<br />FRA, Holley Powershot filter, Whisper Lid, Ported Throttlebody<br />2000 manifolds, Flowmaster, WS6 Tail Pipes, <br />MSD 8.5mm Wires, MSD Coils, Autolite plugs<br />Performance Cryogenics treated rotors<br />1LE Sway Bars and panhard rod, 1LE front springs w/SLP Bilsteins, stock rear springs w/ 3rd Gen Bilsteins, BMR STB, KBDD SFCs, 1LE rear lower control arms, 1LE front lower control arms<p>1968 Chevelle Malibu 327 TH350
you guys with the 255/50 Kumhos...they did look bubbled out of the rim because they were to wide? or did it fit nicely? I'm also getting some Kumhos but still havent decided between the 245's and the 255's.<b>.::[ 0 ]::.</b><br /><b>1997 Camaro 3800 II M5</b> (30th edition)<br />[]B&M Ripper Shifter<br />[]Proform Shift Light<br />[]SLP Cold Air<br />[]Dynomax Exhaust<br />[]Richmond 3.73\'s<br />[]Zexel-Torsen LSD<br />[]180* Thermostat<br />[]Tail Blackouts<br /><a href=\"http://photos.yahoo.com/skyracer_x\" target=\"_blank\">pics</a>
<blockquote>quote:</font><hr>Originally posted by marco:
you guys with the 255/50 Kumhos...they did look bubbled out of the rim because they were to wide? or did it fit nicely? I'm also getting some Kumhos but still havent decided between the 245's and the 255's.<hr></blockquote>
How wide are your rims? 245s and 255s work well with 8 to 9 inch wheels.<b>99 Camaro Z28 A4</b><br />R.I.P. 00 Firebird 3.8<br />14.89 @ 90, 2.03 60\'
shortdog, im running the OEM 16x8 5-spoke rims found on 97-99 Camaros. [img]graemlins/burnout.gif[/img]<b>.::[ 0 ]::.</b><br /><b>1997 Camaro 3800 II M5</b> (30th edition)<br />[]B&M Ripper Shifter<br />[]Proform Shift Light<br />[]SLP Cold Air<br />[]Dynomax Exhaust<br />[]Richmond 3.73\'s<br />[]Zexel-Torsen LSD<br />[]180* Thermostat<br />[]Tail Blackouts<br /><a href=\"http://photos.yahoo.com/skyracer_x\" target=\"_blank\">pics</a>
I think I know what you're saying. You don't want a tire too big that'll make your rims look small? I have 8.5" rims and my 255s fit perfect. You have 8s, so 245 or 255, take your pick. If you like em wide, go with the 255s.<b>99 Camaro Z28 A4</b><br />R.I.P. 00 Firebird 3.8<br />14.89 @ 90, 2.03 60\'
I luv'em wide...looks meaner..wouldnt you think. by bubbly i mean like when they are too wide and look wider than the rim...so around the edges of the rim the tire is popping out...because its significantly wider than rim itself. but yeah..i think 255's should go in nicely. [img]graemlins/burnout.gif[/img]
[ February 21, 2002: Message edited by: marco ]</p><b>.::[ 0 ]::.</b><br /><b>1997 Camaro 3800 II M5</b> (30th edition)<br />[]B&M Ripper Shifter<br />[]Proform Shift Light<br />[]SLP Cold Air<br />[]Dynomax Exhaust<br />[]Richmond 3.73\'s<br />[]Zexel-Torsen LSD<br />[]180* Thermostat<br />[]Tail Blackouts<br /><a href=\"http://photos.yahoo.com/skyracer_x\" target=\"_blank\">pics</a>
