you are being pulled by a truck and when you go to stop you have to stand on the brakes because there is no power and then they start to vibrate really bad and the rotors turn blue?
Is it bad when....
Are you sure that you didn't stop too quickly and were trying to stop the truck that was pulling you too? Usually the reason they turn blue is due to getting too hot. Id say you screwed your brakes up.2000 GTP<br />Thrasher CAI, 3.4\" pulley, DHP PCM<br />Member RedLineVSix<br />Best ET-14.02<br />Best Trap-97.15
