sway bar swap - FirebirdV6.com/CamaroV6.com Message Board
sway bar swap
  • sway bar swap
    i have a 99 firebird. the front sway bar is broken. i most likely be replacing it with a lesser year than mine. do i need to replace both front and back since the size difference?
    Re: sway bar swap
    http://tech.firebirdv6.com/suspension.html
    No. You have a 28/15 setup. Go with a 30mm at least from a 93-97 car - V6 or V8 doesn't matter. Front bar size matters the most.
    Raven
      Re: sway bar swap
      so 30/15 is ok
        Re: sway bar swap
        I ran a 32/15 on my 94 and liked the way it felt so you should be fine.
          Re: sway bar swap
          32/21 1LE set up. I rocked that on my v6 and LOVED it.
            Re: sway bar swap
            GM dropped this setup after only one year. Too much oversteer. You need very high front spring rates for a rear 21mm bar.
            Raven
