steering issue - FirebirdV6.com/CamaroV6.com Message Board
steering issue
  • steering issue
    I noticed when I make a circle going left, you can feel what can only be described as like a wobble in the wheel, kinda feels like the right one. it turns smoothly until about the same spot where it feels loose
    any ideas?
    Re: steering issue
    Odd that you mention it. Mine has a little weirdness as full lock left as well.
      Re: steering issue
      Jack it up and pull on the wheels 10 and 2 oclock and 6 and 12 oclock to see if theres any play in the bushings.
        Re: steering issue
        no play in the bushings, even tried tightening the lugs to see it that was the cause. i did notice however, that when in park, if you turn the wheel all the way to the left or right, right before you make the maximum rotation, the steering wheels vibrates..
          Re: steering issue
          Might be your power steering pump is going bad.
            Re: steering issue
            It's called steering "pulse". Weak PS pump, slipping belt, low PS fluid, etc.
            Raven
              Re: steering issue
              anyway to fix it? or just wait til it craps out?
                Re: steering issue
                You could see if its leaking or not then I guess wait until it craps out if it is indeed your pump or not.
                  Re: steering issue
                  the fluid level does go low quite often, but there's no puddles in the driveway.
                    Re: steering issue
                    Check the hoses and see if they are coated in sticky goo.
                    Raven
                      Re: steering issue
                      The make a stop leak for power steeriing fluid matbe try that when its down in fluid.
                        Re: steering issue
                        Try a P/S fluid flush get all new fluid in there when the fluid gets old it gets thin and does not work as well.
                        like any other oils and fluids needs to be changed.
                        1999 Camaro V6 A4<br />Navy Blue metallic<br />Intake+Exhaust+4.10+?=?
