Steering Issue - FirebirdV6.com/CamaroV6.com Message Board
Steering Issue
  • Steering Issue
    Was backing out of a parking spot at work - making hard left turn to the lock. Hear a pop from the front end. WTF was that? Straighten wheels to drive down isle and realize that the steering wheel is now 45 DEGREES TO THE LEFT when going straight!!!
    Drove the 7 miles home - no steering issue but crooked steering wheel. Inspected - no leaks, nor does anything look wrong under the car.
    OK gurus of the site - WTF happened? Run the pinion off the rack?
    Raven
    Re: Steering Issue
    http://ls1tech.com/forums/suspension...g-tonight.html
    Raven
      Re: Steering Issue
      So was your rack loose?
        Re: Steering Issue
        Was it your A arm bolt or inner tie rod?
          Re: Steering Issue
          Will find out for sure Friday, but it would appear the the pinch bolt at the rack slipped.
          Raven
            Re: Steering Issue
            Well, the pinch bolt and steering linkage is fine.
            Both side lower front A-arms slipped in the K-member adjustment slots.
            Same as this guy:
            New alignment and everything OK.
            Raven
