98+ with factory 9" wide rims on front - FirebirdV6.com/CamaroV6.com Message Board
  • 98+ with factory 9" wide rims on front
    What is the gap between the rim and the spindle?
    Raven
    Re: 98+ with factory 9" wide rims on front
    I have OE wheels C6 replicas 17x9.5 and they clear no problem.
    Hope that helps.
      Hope that helps.
      Nope.
      One spindle is bent and I need to figure out which one.
      Raven
        Top of the tire or down by the rim?
        I will measure tommorow morning when its light out.
          Thanks, but you have 9.5" and I have 9" - so it won't tell me what I need.
          Raven
            I have the trans am speedlines like you, if you tell me the points you would like me to measure between i can do it in the morning and let you know.
            Team NoVa
              Perfect!
              Top of the rim (at the tire bead) to the spindle.
              Raven
                Kinda hard to get it, looks to be between 7/8 and 15/16 of an inch.
                Team NoVa
                  I thought about jacking it up, but that would have changed the geometry.
                  Team NoVa
                    Nope - cause wheel is bolted to hub, and hub is bolted to the spindle.
                    Raven
                      Duh, i didnt even think about that. Is the measurement what you needed? Tell you anything? My car is in storage right now, so if need be i can remeasure, i'll be headed back up there in a bit to work on preparing some parts and fiddling around.
                      Team NoVa
                        How did you bend a spindle Robert?
