Need new rotors - FirebirdV6.com/CamaroV6.com Message Board
Need new rotors
  • Need new rotors
    Well I need new front rotors and I want to go ahead and upgrade them. I've heard so many different opinions on whether or not to get drilled and slotted rotors or just slotted rotors. So what do you guys think, which are better?
    Re: Need new rotors
    Logic says that a blank rotor will have more wear surface, less stress concentrations, and a larger heat capacity than an equivalent rotor with holes and slots. This can also lead to increased pad wear rate. I look at it as an aesthetic modification that can have negative effects on pad/rotor life. I ran drilled rotors for a year or so without issue and then sold the car. It would be an extreme disappointment for rotors to last only a year, so that's not saying much. Your best performance will likely be with a high quality blank.
    1996 Chevrolet Camaro
    1995 Buick Park Avenue Ultra
    --Appearance Moderator--
      Re: Need new rotors
      ^ Like he said stick with good flat rotors. Unless you are racing and need more heat dissipation you're only going to have weaker rotors with slots and/or holes.
      96 White M5 Camaro. Manual everything. Magnaflow cat, dynomax dual outlet axle back. Swapped to a disc rear with 3.42s and a torsen differential, kyb gr2 rear shocks, moog rear endlinks.
        Re: Need new rotors
        Well I don't race the car at all considering it's a daily driver. It was just an idea I was considering. Thanks for the info and opinions guys.
          Re: Need new rotors
          4 yrs and 20,000 miles ago i went with a $300 set of ebc drilled and slotted rotors and ebc pads, i believe the red box, step below the ceramic. they've held up really good and ive gotten a few compliments on how awesome they look. i bought the car from my sister and the stock rotors were bad so i replaced with these, so i cant really give you a good comparison with the stock ones, all i can say is that im really happy. the pads could be a little cleaner as far as brake dust and rim cleaning. apparently the drilled holes are a place for cracks to start but ebc's holes arent all the way through and are more like dimples. the entire rotor seems to come dipped in a black coating, then your breaking surface wears shiny and the slots and holes stay black and never rust. id totally buy em again.
          rotors: http://www.summitracing.com/search/b...c&autoview=SKU
          pads: http://www.summitracing.com/search/P...?Ns=Rank%7cAsc
          looks like the price went up.
            Re: Need new rotors
            If you just daily drive the car there is no point in upgrading the already good brakin system you have. If you wanted to upgrade go to a vette rotor setup. Ive noticed no difference in stopping power with going from solid disc to a drilled or slotted rotor.
            87 Firebird RIP
            96 Camaro RS RIP
            94 Patriot Red 1LE Z28 - Sold
            02 WS6 TA - Sold
              Re: Need new rotors
              The other reason I was thinking of picking up the slotted rotors is because when it rains, my brakes are next to useless for a brief moment when first applied.
              Edit: Not sure if the slots would help this or not.
                Re: Need new rotors
                Not at all.
                Although ws6store had $160 for 4 rotors when I bought from them.
                  Re: Need new rotors
                  How have they held up? How many miles have you had them on for?
                    Re: Need new rotors
                    They've been good. Just a DD also, about 10 or so k miles. I'd buy them again.
                      Re: Need new rotors
                      Perfect, I think I'll go with those. I've read a lot of good reviews on them and they aren't really expensive either.
                        Re: Need new rotors
                        Also have EBC rotors on the bird, and will be installing on the Implala SS shortly.
                        Raven
                          Re: Need new rotors
                          Alright well I decided I'll be ordering 4 slotted rotors off ws6store as well as ceramic pads off of there as well. In total I'll be paying around 320 depending on shipping.
                          Thanks for all the info and suggestions guys, I appreciate it.
                            Re: Need new rotors
                            just to let you know the ceramic pads last a long time but you will loose some braking ability with them. im running ceramics right now and considering swapping them out for a pad with more iron in them. i just need to get them to wear some more before i swap them out. if hawk pads were not so expansive i would grab a set of them.
                              Re: Need new rotors
                              So I got my rotors and pads installed yesterday with no problems, and they work great. Only thing is I have to pull my e-brake up to where its almost vertical for it to engage, when beforehand with my old brakes it only had to be up at about a 45 degree angle. Any ideas whats going on?
