Can I use 2xx/40/16? - FirebirdV6.com/CamaroV6.com Message Board
  • Can I use 2xx/40/16?
    I was wanting to get 215 or 225 40 series tires but I'm not sure if they will work on my rims. They are 99-00 Firebird OEM.
    1993 Pontiac Firebird 3.4L V6 A4<br />F41 RPO suspension option<br />119K miles<br />Fastchip<br />K&N \"Filtercharged\"<br />Airbox cuttout CAI<br />ASP underdrive pulleys<br />Pacesetter Headers<br />Flowmaster 80 Series 2.75 cat-back<br />MangaFlow Hi-Flow Cat<br />Corvette Servo<br />16.4 @ 81 MPH
    If you go to the tirerack.com website and look up the tire you want, you can then click on specs. It will give you a list of all the available tire sizes, and will tell you what the minimum and maximum rim widths will fit it. Like here is the link from tirerack for the Kuhmo Ecsta Supra 712, I got these a few weeks ago for my front tires and like them so far.
    AIM: Alientr8tr<br /><a href=\"http://www.cardomain.com/memberpage/583450\" target=\"_blank\">1998 Camaro 3.8L</a><br />Flowmaster 80-series, !FRA, Eibach Springs, KYB AGX, SLP sway bars, 3.42/LSD, Wings West kit, Z06 Motorsports, Silverstone Metallic paint<br /><a href=\"http://www.shift5.com/\" target=\"_blank\">Shift 5</a> - My Band
      yeah, it'd fit, but why have such a small tire?
      your gearing/speedometer would be WAY messed up.
      if you're gonna go 40 series, grab some 255's
      2011 Camaro LS 6M, in black.
        Where can I get a speedo/odo fixer? Can I get I custom chip somewhere?
          if u want a narrow tire, u can put
          215/60/16s on with no problem
          they're the same height as 245/50/16s
            the lowest I have seen are 245/45/16 and they are sweet even on stock rims not to mention real performers when it comes to handling. and the widest I have come across are 265/50/16 for our cars, so it up to what ever look you after.
