i just ordered 10.5 wide rims. if i got 315s for the rear tires, is it gonna rub against my well? also what size should i get for the 9.5s in the front, that is if they are even gonna fit.
315s in the rear
i think you may have to roll the lip on the rear fender to make the 315's fit but i could be mistaken....also get 275's for the front....<b>Black</b> 1998 Pontiac <i>Firebird</i> A-4 swap<br />271.4rwhp/259.4rwtq NA<br />13.30@102.44 <br /><a href=\"http://www.freewebs.com/wickedsix98\" target=\"_blank\">www.freewebs.com/wickedsix98</a>
I have heard the 315 will rub. However, with some gentle manipulation with a sledge, it should fit.2001 Firebird 3.8L V6 M5,<br />It once had....<br />NX Nitrous Wet Kit, ZZP X-P Hot Cam, <br />3.42 LSD, Pacesetter Headers, <br />36# Injectors, HP Tuners<br />322 RWHP, 379 RWTQ<br />13.596 @ 102.56 w/100 shot
I think you have to take out the bump stops or something. I know where they are but cant think of the name. They will definetly fit on the rear, without too much modification. Also, get the 275/40's for the front. Mine are 9.5" and it fits almost perfect, next time I will go with 285/40's. But that is just my preference. Good luck, ;)Jordan<br />15.09@90.7<br /><a href=\"http://www.fullthrottlev6.com/forums/vbgarage.php?do=view&id=21\" target=\"_blank\"><b>1995 Camaro 3.4 M5</b></a>
The 315s should fit out back without having to roll the fender lip. However i think the bump stops need to be modified a little bit. No major work is needed, just some patience... an adjustable panhard rod will center everyting up for you. Good Luck!2000 Monterey Maroon Chevrolet Camaro<br />3.8L V-6/4spd Auto
by DoodlerHi, everyone. We bought a 97 base model convertible Camaro and someone broke the motor ... Lights were blinking on the dash and that someone ignored the...11 hours ago
by ssms5411Still trying to find oil leak on my Camaro, it’s a tough one. I think it is the oil pressure sender myself. Leaking when raving and going into boost....4 days ago
