Yesterday I set up an appointment with Mr. Tire for a new set of the V rated Yoko's. Shortly after I blew one of my Eagle GA's so these Yoko's are going on no question. Has anyone had these tires and if so how'd they handle compared to the GA's I would be interested to know. Thanks.
Yokohama 245/50
Yokohama 245/50
95 3.4L <br /> <a href=\"http://www.myspace.com/1277388\" target=\"_blank\">http://www.myspace.com/1277388</a> <br /> <a href=\"http://www.cardomain.com/profile/altspacen\" target=\"_blank\">http://www.cardomain.com/profile/altspacen</a> <br /><a href=\"http://groups.myspace.com/camarov6\" target=\"_blank\">http://groups.myspace.com/camarov6</a>Tags: None
I wouldn't even consider the V4S's unless you just care about saving $2 a tire and having a higher tread rating than the ES-100's (but at the expense of worse handling and performance.)
I believe Goodyear Eagle RH's came with my Camaro...and they weren't too bad for Goodyear tires (and I don't like Goodyear tires at all!). The Yokohama ES-100s are soo much better though! :D
[ September 03, 2004, 06:16 PM: Message edited by: Vracer111 ]<a href=\"http://www.cardomain.com/id/vracer111\" target=\"_blank\">My \'98 Camaro</a><br /><br /><a href=\"http://www.honda-tech.com/garage?cmd=viewcar&id=1223\" target=\"_blank\">My \'98 Tacoma</a>
AVS ES100's arent too bad a tire. If you want to know how they are going to compare to the GA's, well they are going to kick their ***. If I remember right, the stock Eagle GA tire was a T rated tire. Either that or H. So Yeah a V rated tire that is a yokohama is going to be better.Jordan<br />15.09@90.7<br /><a href=\"http://www.fullthrottlev6.com/forums/vbgarage.php?do=view&id=21\" target=\"_blank\"><b>1995 Camaro 3.4 M5</b></a>
