Low traction, sensor probs? '95 Bird - FirebirdV6.com/CamaroV6.com Message Board
  • Low traction, sensor probs? '95 Bird
    Still looking for a service manual but...
    My abs is clicking when I roll to a stop & the Low Traction light is coming on.
    There is no evidence of mechanical maladies so:
    Can the speed sensors be checked or cleaned?
    Standard wheels & tires, FYI.
    The rear end and brake fluid are recent (as always with a recent purchase)
    Thanks!
    Re: Low traction, sensor probs? '95 Bird
    Bumparoo!
    Anyone?
      Could be a bad wheel sensor.
        Well, I pretty much ruled out the wiper motor....
        Still have not gotten a shop manual just yet,
        can you elaborate or do I need to keep looking for a thread on this?
          If this is a recent purchase and there is any evidence the rear end might have been swapped at some point there were different rear end sensors for the abs/traction control setup. One had sensors for each wheel in the rear the other had a single sensor in the pumpkin. If it doesn't match what your car was wired for initially it can cause some odd behavior from what I've read.
          96 White M5 Camaro. Manual everything. Magnaflow cat, dynomax dual outlet axle back. Swapped to a disc rear with 3.42s and a torsen differential, kyb gr2 rear shocks, moog rear endlinks.
