I know we have all seen this question time in and out but I just need some help with my car man, I am about to get pissed and just forget the T.L.C> were suppose to have. What my problem is as of latley I have been bottoming out way toooooo much. I have beilstin shocks and eibac sport springs, which both are not even a year old yet, I inly have 29,000mi and some change on the car itself, I havent messed with the sway bars execpet rear end links, and I have deceint tires and 18'' wheels, so Y OH Y is mu stupid ride bottoming out allmost all the time.. EXSAMPLE. I be driveing and make a right turn and maybe go e=over a slite dip and at first its allright but If I am going alittle faster, and hit a couple of pot holes or a smalle dip My car will bounce and fill like no softness and then the loud clunk noise from under the car. what am I to do please
Man I just dont understand my suspension
Thanks bros. I think I may have messed up my shocks? But I will check out the exsust and I dont think its the jounch bumpers, the instructions said I didnt have to trim them, also It just as of latley my car is bottoming out and makeing werd sounds. When I first had the springs and shocks installed along with wheels and tires, I hadn't had any problems. I just wounder if the SFC are not right . they were installed the other day and at first only the front was welded and rear was bolted, but I had the rear welded later but I dont know if the set up was correct. only the camaro gods know I guess. ride on bros..
gman211203member.cardomain.com/gman211203
I think I found the problem. I seemed to have bad ball joints in the control arm, uper and lower, probley worn out from upgraded stuff and driveing pretty hard on the car. So I am getting fixed and hopefully I wont have any problems for awhile. Thanks again camaro folks for your help and understanding..Gman211203member.cardomain.com/gman211203
A bad ball joint wouldnt contribute to you bottoming out all the time. Its just because you lowered your car. I lowered mine, and I cannot go over a speed bump, without my exhaust scrapping. Just the facts of life. Good luck. ;)Jordan<br />15.09@90.7<br /><a href=\"http://www.fullthrottlev6.com/forums/vbgarage.php?do=view&id=21\" target=\"_blank\"><b>1995 Camaro 3.4 M5</b></a>
Well my camaro pals, I have seemed to fix my suspension problems I was complaining about. I changed my front end links with some prothan end links and I had my allignment corrected and I don't bottom out continueiously anymore. I do want to thank you guys again for your addvise and humurious remarks, And I will continue to try to spell better and slow down on the highway. Thanks Gman211203member.cardomain.com/gman211203
