I want to put 17' wheels on my car however, I was told that our stock rim/tire combo doesn't evenly match up to any 17' rim/tire combo. I was told that if I put any size 17 I will actually increase my milage pur revolution of the wheel. Is there a rim/tire combo that works without having to adjust the PCM for a diffent size rim/tire.
17' Rims and Odometers!!!
Yea, 285/40R17 would be your best bet, they would only be off by 0.77%
check out:
http://www.c5-corvette.com/tirecalc.htm for other combos1996 3.8L V6 Camaro A4 Y87<br />Flowmaster 80 Series<br />LPE Cold Air Induction<br />LPE 1 Piece Aluminum Driveshaft<br />BMR Torque Arm<br />Window Tint 5%/5% Sides/Back<p><a href=\"http://members.cardomain.com/adinsx\" target=\"_blank\">http://members.cardomain.com/adinsx</a>
Get some 17x9 wheels, and 275/40R17s. They are the same height as my winter 215/60R16s. Yes, I measured them side by side.--<b>David</b>--<br /><a href=\"http://bryant2.bryant.edu/~dsantore/index.htm\" target=\"_blank\">The <b>NEW</b> V6Bird Website!</a> <br /><a href=\"http://members.cardomain.com/thev6bird\" target=\"_blank\">Cardomain site</a><br />ΔX
I measured my Kumho 275/40R17s up to my stock michelins. (235/55R16s) Almost exact. Your talking a 1% difference or so.
Just so you know, your speedo will become more and more "off" as your tires wear. From say 11/32nds down to 3-5/32nds. A radius change of up to 1/4 inch!. I won't go into detail on how much that will through you off, but I bet you have never noticed.
It really isn't problem, nor is it noticable in moderation.1997 Chevrolet Camaro v6 - 13.8@104MPH
1997 Dodge Viper GTS
I agree with AZ on the tire wear issue - thats the real reason why P275/40 (25.7" high) is in all ways identical to the P285/40 (26.1" high) as far as the odo is concerned.
The other accurate tire choice is the P255/45R17 [img]smile.gif[/img] (fits a 17x8 or wider)2002 5-spd NBM Camaro
Details: www.1lev6.com
by DoodlerHi, everyone. We bought a 97 base model convertible Camaro and someone broke the motor ... Lights were blinking on the dash and that someone ignored the...1 hour ago
