I have a friend that recently crashed his SS camaro and I got parts off of his car as hopefully upgrades for my 3.8 2000 Camaro. His car only had about 50k miles where as mine has well over 120k. So some of this stuff might be better from just age, but I dont know if some of the stuff is compatible or an upgrade. Maybe it hurts performance??
I got the shocks, they were KYB GR-2s from the front with the springs (dont know if the springs are stock or aftermarket yet) but the shocks are not adjustable and was wondering if they would work. Without making raising the car or making it stiffer since these were on an SS camaro. I am actually thinking about lowering the car anyway so if this shocks would work with aftermarket lowering springs, that would be perfect.
Another thing I got was the whole spindles assembly with hub caps/bearings. I am pretty sure those would work. Dont think they are any different at all.
I also picked up a set of drilled rotors (aftermarket) and the calipers (stock) off the SS. I dont know if the calipers are any different.
I also got the sway bar which I know is bigger but I dont know if its worth the effort in putting it in. Also got an aftermarket strut tower brace he had bought for it, but not sure if that would work on the V6 car. I think the mounts are different
Got the aluminum drive shaft, mine is the steel one piece, I know the aluminum is a little lighter. Any other advantages of swapping them out?
Anyway, Let me know what you know. What is compatible and what's not and what's actually worth swapping out or adding. Like I said, he was pretty much junking the car after he took the engine and tranny out so I got all this stuff for free. Drinks at the bar don't really count :burn:
Thanks in advance!
Thanks in advance!
