I am on the process to upgrading my whole suspension. Picked up some aftermarket shocks and springs form a friends wrecked camaro SS. I got bilstein shocks for the back and KYB GR-2s in the front. The lowering springs are eibach which I already swapped because the stock SS ones he had on there would have been too strong for my V6 2000 camaro.
As I was replacing the shocks, I realized I had never replaced the control arm bushings and they are def do (since the rear bushing in the front lower control arm is know to go bad in these cars). I will prob replace the ball joints since I already got it all apart.
So I was trying to get it off. I got the spindle and shock assembly out of the way. I see 2 bolts, one towards the front and one in the back. I got the nut off the one in the front but the bolt is too big and the steering rack gets in the way to pull it out.
The one in the back is in a weird spot where I got the nut off at the bottom but I can't get the bolt off either.
Any suggestions?
Also, any recommendations as to which bushings to get? (Brand) or ball joit?
Thanks in advance
Any suggestions?
Thanks in advance
