I just bought a 32mm front and 19mm rear sway bar and was wondering what all I needed for install. Obviously will need new bushings for the bigger bars, but would I need just the bushings, or the bracket that mounts them too, or can I reuse the old one? Also will I need new endlinks and what length endlinks would I need?
Bought new sway bars
Re: Bought new sway bars
the universal endlinks should work well for you on the front. your going to need 1.5 inch spacers on the rear endlinks you can just buy a set of univeral links and cut them to size and buy the right size bolts. for the bushings go with the grease able poly bushingsfor front and rear.
