hey guys :wavey:
so i have been in the middle , coil overs or stock.
i want this too be a street / track set up. i will be doing some auto cross but just for fun , the strip is more were i will be at. and also right now my bird is my daily driver and i want to do research and get opinions/help before i buy and put the parts on. :work:
so far i have seen positive responses with a 32 mil front sway bar and 21 mil rear sway bar. i am also going to upgrade my lower control arms and ball joins and rotors since i need new ones .along with a strut brace . panhard bar, as for tires i am still looking into that and going to keep the stock rims
here are the part i have decided with
sway bars:http://www.summitracing.com/parts/hss-2204
lower control arms;http://www.summitracing.com/parts/bmr-aa002r
strut brace: http://www.summitracing.com/parts/bmr-mstb002r
panhard bar:http://www.summitracing.com/parts/upi-2038cm-r
any suggestions will help also
i have been researching about coil overs on here but there's not much info about it and just lowering my car i would not like for the reason that my car all ready scrapes when going over speed bums and is not adjustable.as for coil overs maybe people don't use then on our bird. the reason i have been looking into them is that the adjust ability you can do in an instant at the track and also for a looks,u can lower when you just want too park and show your car. :naughty:
so far i have narrowed it to these :
http://www.summitracing.com/search/p...d=coil%20overs
my question are : what are number of valving selections mean?, lower mount tie bar or bering? single or duble adjustable?
as for the spring that you have to buy seperately i have these narrrowed down http://www.summitracing.com/search/p...over%20springs
my questions on these are , whats spring rate mean? and which is best if i do go with coil overs?
and as for the rear axle how would this work on the rear?, cause the rear has the spring and shock separated.
if i do go with stock this is what i have picked out
shocks:http://www.summitracing.com/parts/bsn-24-024068http://www.summitracing.com/parts/bsn-24-024075
springs:http://www.summitracing.com/parts/mog-60114
http://www.summitracing.com/parts/mog-cc635
any info can help, thanks
