i already have gfx and ZR-1 rims. im going to lower the car with suspension techniques springs 1.2 front and 1.7 rear. i read on camaroz28.com that one guy with the same rims put the eibach sportlines on that lower the rear 2" had no problems with rubbing.
1999 White Ford SVT Lightning.<br /><br />Hoping to dyno @ 450hp/550tq by the end of \'04.
do shocks w/ the springs. w/ the rims, u may wanna roll ur fenders out a little. The gfx should be cool as long as u don't go straight up steep driveways.
I don't see why you'd need to roll the fender lip. So long as you have the right size wheels 315's should fit, even with a suspension drop with no rubbing. The ones that require work to fit are 345's. 315's shouldn't really be anymore than a simple tire change. I've seen them on several F4's with no rubbing - even autocross junkies.
Congratulations though, I was hoping to be the first V6 with 315's but oh well. Lemme know how the traction works out for you once their bolted up. I plan on doing everything you are doing, except I plan on running 295's up front.
<b>15.41</b> @ 89.80 & 15.45 @ <b>91.64</b>, 2.21 60ft, 3,440 raceweight, using <b>OEM</b> Equipment. <br />\'98 L67/M49 w/ 134,000 miles before spun bearing. \"<i>It\'s all stock, Baby</i>!\"
actually, there is a guy who already did 17x11 w/ 315-35 tires on here. He'll have to roll his fenders with the ZR1's because of the offset they come w/. if they were custom offset ZR1's then maybe he won't have to roll them out.
<blockquote>quote:</font><hr>Originally posted by andrew N.: the tri-fecta:
lowering springs going on in a week,
ground effects,
17X11 rear wheels with 315 rear tires.
i can make it work.<hr></blockquote>
post some pictures before you start riving it when you are done.. I bet in 2-3 days you will knock off some ground effects. I lowered my car and scrape front bumper everywere without groundeffects!!
Jeff ..
1998 Firebird.. Built 3.8 with a 125 shot.. 370rwhp,415rwtq.. stock tune!! sold
