upper ball joints - FirebirdV6.com/CamaroV6.com Message Board
upper ball joints
  • upper ball joints
    Are all upper ball joints supposed to have a metal boot retainer? I just replaced my passenger side ball joint but 3 things happened that concerned me.
    1) when I went to torque the castle nut down to 39 ft lbs of torque, the bolt stripped...this leaves me to wonder if something isnt right, or my torque wrench is off... since I had 2 ball joints, I put the second one in and hand tightned it until the castle nut went past the cotter hole and tossed the cotter pin in place...
    2) I dont recall seeing a metal boot retainer on the new piece
    3) I went for a test drive the the car still squeaks, just not as bad...Granted my upper control arm bushings are also shot, and it could be that...
    Im going to probably order some upper control arms by the end of this week, I want to be sure that my car is safe however and that I installed everything correctly.
    Re: upper ball joints
    I would say its good since you got the cotter pin in there. I wouldn't think its going any where. Did you fill up the grease fitting with grease?
      it was a sealed ball joint...There was some kind of collar that was around the factory one though that was bent to hell...I just don't know if that was supposed to transfer over or if that even matters?
        Shouldn't matter I'm surprised that the new one didn't have a grease fitting.
