Would the size difference be enough to mess up the speedo when going from the factory Goodyears(235/55) to a set of BFGs(245/50)?
235/55 to 245/50
i dont think it will.. i went from same sizes, never knew anything about it messing up speedo.. but seems fine99\' W68 Firebird<br />SLP Ram air kit,Whisper Air Lid, k&n, 8mm Taylor Wires, Bridgestone Potenzas RE950, BMR Red LCAs, Pacesetter Headers and 3\"in catalytic converter with 2.75\" Flowmaster Cat-back<br /><br /> <a href=\"http://www.cardomain.com/memberpage/501008\" target=\"_blank\">http://www.cardomain.com/memberpage/501008</a>
it will be so slight you will never tell.
That is 5 millimeters of length on the tire wall. If I remember chemstry correctly, that is 1/2 centimeter...just to explain what a slight difference that is.-1999 Camaro Coupe 3800 Series II V6 A4 - SOLD<br />-1998 Pontiac Grand Prix GTP coupe
You have a 2000, so you can buy an HPP3 for what 350 dollars? About the easiest way.
However, 350 dollars for maybe 2mph off? Seriously if anything it will help you. You'll think you're cruising at a higher speed than you really are, cops may leave you alone for doing 77 on the interstae when you're really doing 80 or around. I know that may seem far fetched, but I know if I was a cop and i saw a big 80 on my gun, I'd be more tempted to chase you down rather than doing 77-78mph.-1999 Camaro Coupe 3800 Series II V6 A4 - SOLD<br />-1998 Pontiac Grand Prix GTP coupe
The difference in diameter between the 2 is 1cm, 3.14 cm circumpherence difference. If you compare that to the total circumpherence of your tires its not too much, so id agree with ignoring it. And like they said going smaller makes it seem like your going faster than you really are so its not a problem.M5, posi, headers-3\"hooker catback, spec2, alum DS, whisper lid & K&N, hurst, eagle 077s w/kumho supras, subframes, 3point stb, trans hatch
You'll read faster on your speedo, by like 1.5 mph at 60. So your actually going 58.5 when it says 60. I made this switch about a week ago when I switched from the Eagles to some Yoko's.95 3.4L <br /> <a href=\"http://www.myspace.com/1277388\" target=\"_blank\">http://www.myspace.com/1277388</a> <br /> <a href=\"http://www.cardomain.com/profile/altspacen\" target=\"_blank\">http://www.cardomain.com/profile/altspacen</a> <br /><a href=\"http://groups.myspace.com/camarov6\" target=\"_blank\">http://groups.myspace.com/camarov6</a>
by DoodlerHi, everyone. We bought a 97 base model convertible Camaro and someone broke the motor ... Lights were blinking on the dash and that someone ignored the...7 hours ago
by ssms5411Still trying to find oil leak on my Camaro, it’s a tough one. I think it is the oil pressure sender myself. Leaking when raving and going into boost....4 days ago
