235/55 to 245/50 - FirebirdV6.com/CamaroV6.com Message Board
235/55 to 245/50
  • 235/55 to 245/50
    Would the size difference be enough to mess up the speedo when going from the factory Goodyears(235/55) to a set of BFGs(245/50)?
    2000 Monterey Maroon Chevrolet Camaro<br />3.8L V-6/4spd Auto
    i dont think it will.. i went from same sizes, never knew anything about it messing up speedo.. but seems fine
    99\' W68 Firebird<br />SLP Ram air kit,Whisper Air Lid, k&n, 8mm Taylor Wires, Bridgestone Potenzas RE950, BMR Red LCAs, Pacesetter Headers and 3\"in catalytic converter with 2.75\" Flowmaster Cat-back<br /><br /> <a href=\"http://www.cardomain.com/memberpage/501008\" target=\"_blank\">http://www.cardomain.com/memberpage/501008</a>
      it will be so slight you will never tell.
      That is 5 millimeters of length on the tire wall. If I remember chemstry correctly, that is 1/2 centimeter...just to explain what a slight difference that is.
      -1999 Camaro Coupe 3800 Series II V6 A4 - SOLD<br />-1998 Pontiac Grand Prix GTP coupe
        With the 245/50s your speedo will read about 2mph higher at 60 than it does now.
        2000 Firebird convert, chameleon/tan, M5, Y87, TCS, BMR tower brace and panhard, KBDD sfcs, 245/50-16 GSCs
          Is there an easy and cheap way to fix that?
            You have a 2000, so you can buy an HPP3 for what 350 dollars? About the easiest way.
            However, 350 dollars for maybe 2mph off? Seriously if anything it will help you. You'll think you're cruising at a higher speed than you really are, cops may leave you alone for doing 77 on the interstae when you're really doing 80 or around. I know that may seem far fetched, but I know if I was a cop and i saw a big 80 on my gun, I'd be more tempted to chase you down rather than doing 77-78mph.
              ditto. Dont worry about it.
              Jordan<br />15.09@90.7<br /><a href=\"http://www.fullthrottlev6.com/forums/vbgarage.php?do=view&id=21\" target=\"_blank\"><b>1995 Camaro 3.4 M5</b></a>
                The difference in diameter between the 2 is 1cm, 3.14 cm circumpherence difference. If you compare that to the total circumpherence of your tires its not too much, so id agree with ignoring it. And like they said going smaller makes it seem like your going faster than you really are so its not a problem.
                M5, posi, headers-3\"hooker catback, spec2, alum DS, whisper lid & K&N, hurst, eagle 077s w/kumho supras, subframes, 3point stb, trans hatch
                  You'll read faster on your speedo, by like 1.5 mph at 60. So your actually going 58.5 when it says 60. I made this switch about a week ago when I switched from the Eagles to some Yoko's.
                  95 3.4L <br /> <a href=\"http://www.myspace.com/1277388\" target=\"_blank\">http://www.myspace.com/1277388</a> <br /> <a href=\"http://www.cardomain.com/profile/altspacen\" target=\"_blank\">http://www.cardomain.com/profile/altspacen</a> <br /><a href=\"http://groups.myspace.com/camarov6\" target=\"_blank\">http://groups.myspace.com/camarov6</a>
