Sway bar weights/Q1 HAL shocks & Springs? - FirebirdV6.com/CamaroV6.com Message Board
  • Sway bar weights/Q1 HAL shocks & Springs?
    Does going to an aftermarket sway bar set up help our cars loose any weight? If yes how much?
    Does anyone here have the Q1 HAL front springs and all 4 shocks? I read on BMR's web-site they weight like 17lbs less per set. That is -34lbs!
    :D
    Thanks, <br />JAM<p>02 Firebird GT
    Aftermarket bars are larger and heavier than your stockers.
    2002 5-spd NBM Camaro
    Details: www.1lev6.com
      Thanks Dominic! Does anyone here have the Q1 HAL front springs and all 4 shocks? I read on BMR's web-site they weight like 17lbs less per set. That is -34lbs! Thinking about replacing factory shocks with those. Not sure on the springs though. Anyone tried this set up? [img]graemlins/burnout.gif[/img]
        that's a good question. what about the ground control coil-over kit w/ koni shocks? does nebody know how much that setup weighs compared to stock?
          If you're looking for weight savings, you're talking like a drag racer. The people who design suspensions for handling don't usually factor in weight unless its obsurdly high or low. I know for a fact the bilstein shocks are heavier than stock (theyre a lot bigger for one thing), however the gains they provide in ride control makes up for their extra poundage.
          35lbs is not going to make a whirl of difference on a circuit or autox course.
            Yes, but...
            35lbs. shocks
            30lbs spare tire
            12lbs drive shaft
            15lbs dyna batt
            4lbs ligher wheels
            = about 96lbls less, and we can keep going. There is a method to the madness. LOL! So has anyone used the Q1 HAL front springs and all 4 shocks?
            I am just concerned with something this light compared to others that are good shocks. Then maybe they are not as good?
              Keep in mind I will have 17x11's on the rear. Just wante to make sure those lightweigth boys have enough strength. :D
                Theyre good for drag racing, and theyre okay on the street. I hear their firmer settings are extremely stiff and ride bad, and have to ride bad (too much bump to get the right rebound) in order to handle okay. For drag racing theyre great though, good weight transfer. Id say theyre safe shocks to run, but dont look for it to ride better by any means - the HALs supposedly ride badly.
                  Thanks! If they give a sucky ride then I definatly don't want them. :cool:
