I bought a 99 Trans-Am rear axle with TCS and wanna know if it's compatible with my car. The 2 things ive run into that I have a problem with is the ABS and brake lines. I did a search and "For the brake lines...make a t-fitting to attach to the dual lines and allow for a single input" was one of the things I came across (Backfire)...has anyone done this/will it work? Also if anyone has more information on this I'd like to know...as for the ABS is it wise to just plug the sensor into one wheel?
ABS & Brake Lines on Axle Swap
*SLP Cold Air Intake<br />*RK Sport Welded Headers/Y-Pipe<br />*High Flow Cat. Converter<br />*B&B Tri-Flo Cat. Back<br />*Charcoal Leather Interior<br />*Fiberglass Fabricators SS Hood<br />*13.1\"/Dual Piston Corvette Brakes (Front)<br />*12\"/Single Piston Brakes (Rear)<br />*17\" ZR1 w/ 275/40/17 all round<br />*Z28 Dashboard Cluster<br />*99 Trans-Am Rear Axle<br />*35% Side & Rear Black TintTags: None
