Passanger side sits lower than driver - FirebirdV6.com/CamaroV6.com Message Board
  • #16
    Re: Passanger side sits lower than driver
    Are the KYB GR-2 shocks any good? they're half the price of the agx and the bilstien, also do you know if they would be able to hold up to being lowered when the time comes?
    Or in all honesty should I just get oem replacements until I can afford quality shocks and springs?
    • #17
      If you don't have the money now just get some to fix the problem save up and get quality ones
      Sent from my SGH-T999 using Tapatalk 2
      • #18
        Well as much as I wanted to save some money and go the cheap route, I bit the bullet and just ordered a set of KYB AGX shots and BMR 1.5" lowering springs. The issue wasn't not having the money, just being cheap and not wanting to spend it lol. I'll post some before and after pictures once is everything is installed.
        Thanks for all the help guys
        • #19
          Can't wait to see the difference
          • #20
            Will lowering it that much give me an issue with tire camber, or will a good alignment correct any issue I might have?
            • #21
              Well everything is on and it looks great. However, I'm getting a scraping type noise from the front, like metal on metal as if there is no rubber between the shock and the spring. I know everything was put back right, so I'm a bit stumped.
              I'll post some pictures tomorrow in the daylight of the new stance.
