Which springs for Konis - FirebirdV6.com/CamaroV6.com Message Board
  • Which springs for Konis
    I want to know the best springs that will work with a set of Konis, maybe even AGX shocks, and not raise (like SLp TO intended for v8's)or lower my car like 2". i do want an upgrade, and anything less than a 1" drop would be ok too. will stock replacments work, or just keep mine, i need advise, thanks. i am putting on a body kit(WW93-97), and do not want it too low. thanks for suggestions!
    anyone?
      Nearly any spring will work well with a Koni since the Koni is adjustable. The question you should be asking is "Based on my driving style or what I intend to do with the car, what spring rate will I need? stiffer? stock? softer?"
      Check my spring rate database for more help choosing a spring. I recommend starting with the stock springs unless you need the car lowered. Eibachs work quite well until you end up doing 110mph corners on a roadtrack [img]smile.gif[/img]
      2002 5-spd NBM Camaro
      Details: www.1lev6.com
        should i use my stock springs, they have 80,000 on em, or should i go take-offs? i want a nice streetable stiff suspension, nothing to take me around turns @ 70 mph, but something that will offer a superior ride quality and good handling! if that makes sense!
          I put the Eibach prokit on mine. The v8 kit.
          The rear was lower than the front, with the spring on the upper perch slot on the front. Putting the spring on the lower perch slot on the front levelled the car. Top slot will be near stock, bottom slot is about 1.5" drop.
          A v6 kit would probably be level on the top slot.
          I have the factory body kit on mine.
