Are there any pieces from a convertible f-body that can be used to tighten up a coupe? I remember, back in the 60s, factory race cars - like 63 Z-11 Impalas - sometimes used x-members from convertibles to stiffen up the coupe frames. When I've looked up subframe connecters and such, I often see in the description 'except convertible'. There's obviously some difference, any factory parts like x-members, crossmembers, subframe connectors, etc. that would bolt onto my 93 coupe?
Tightening up a coupe with convertible parts?
Re: Tightening up a coupe with convertible parts?
There are subframes you can buy.
http://www.jegs.com/p/UMI-Performanc...71012/10002/-1
Thanks 2.8 bird for the link. Yep, I'm familiar - I spend lots of happy bathroom time reading my Summit and Jegs catalogs. The reason I was asking - I was at my local u-pull-it junkyard (trips to the junkyard always make me happy in pants! :D ), they have a 95 convertible there. If I can get a factory piece that bolts in as opposed to a 500 dollar piece that welds in... I'm sure I'll be going the strut brace/subframe connectors route eventually, but while there's a convertible available, just thought I'd see if there's anything I could use.
Originally posted by wildbill59 View PostAre there any pieces from a convertible f-body that can be used to tighten up a coupe?
1) the K-member is reinforced
2) the trans mount cross-member and tunnel braceLast edited by FirebirdGT; 09-27-2014, 09:42 PM.Robert - owner www.FirebirdV6.com/CamaroV6.com
Raven
Originally posted by fbodyrs96 View Postwhat car did that second brace come off of? mine doesn't have it. an whats the differences in the k member, never really noticed them.
The conv K-member has internal bracing, and the external bracing rods.
Raven
Now that's what I'm talkin' about. Thanks, FirebirdGT - lovin' that tunnel brace! I'll be off to the junkyard today. A couple of quick questions: 1st, My car is a 5-speed, should that tunnel brace mount to a manual crossmember, or could I even use the auto piece with a manual trans mount? And second, that k-member - is it just reinforced with those two rods, or is the whole k-member beefier? Thanks again, this is exactly the info I was looking for!
Originally posted by wildbill59 View PostNow that's what I'm talkin' about. Thanks, FirebirdGT - lovin' that tunnel brace! I'll be off to the junkyard today. A couple of quick questions: 1st, My car is a 5-speed, should that tunnel brace mount to a manual crossmember, or could I even use the auto piece with a manual trans mount? And second, that k-member - is it just reinforced with those two rods, or is the whole k-member beefier? Thanks again, this is exactly the info I was looking for!
Raven
Excellent, thanks! Tell me, will all f-body convertibles have this setup, or just Z/28 and 1LE cars? The car at my junkyard is a V6/auto (didn't get a chance to get to check it out today), I'm really hopin' it has that crossmember/x-member like the one in your garage!
Originally posted by wildbill59 View PostExcellent, thanks! Tell me, will all f-body convertibles have this setup, or just Z/28 and 1LE cars? The car at my junkyard is a V6/auto (didn't get a chance to get to check it out today), I'm really hopin' it has that crossmember/x-member like the one in your garage!
.Last edited by FirebirdGT; 10-01-2014, 06:31 PM.Robert - owner www.FirebirdV6.com/CamaroV6.com
Raven
