Question about BMR STB install...... - FirebirdV6.com/CamaroV6.com Message Board
  • Question about BMR STB install......
    I got the BMR STB for Christmas and installed it this morning. To do the install i had to disconnect the AC sensor. No big deal. STB went on with no problem. But where the AC sensor hooks into the line is right behind the bar. It will not connect behind or in front of the STB (STB is on now, AC sensor is not). Anyone else have this problem? Have a fix?
    Right now its no big deal, i just left the sensor off; but i need to get it back on before it warms back up around here. TIA [img]smile.gif[/img]
    -Justin
    [ December 25, 2002: Message edited by: jhkcam ]</p>
    2001 Camaro Z28 (A4) Sunset Orange Metallic w/ T-tops, Monsoon Stereo, factory GFX, BMR STB from the v6, 18K miles<br /><a href=\"http://www.cardomain.com/id/jhkcam22\" target=\"_blank\">2001 Camaro Z28</a><br /><br />Dads car: 2002 35th aniv. Bright red Z28, fully loaded<br /><br />R.I.P.<br />1995 3.4L Camaro (A4) Bright Red<br /><a href=\"http://www.cardomain.com/id/jhkcam\" target=\"_blank\">1995 3.4 Camaro</a>
    Since its a 3.4 I can only assume you ended up with a V8 bar... what is the shape of the bar?
    2002 5-spd NBM Camaro
    Details: www.1lev6.com
      <blockquote>quote:</font><hr>Originally posted by Dominic:
      Since its a 3.4 I can only assume you ended up with a V8 bar... what is the shape of the bar?<hr></blockquote>
      No. It is the same for all v6's. Its this one:
      http://www.lmperformance.com/521/14.html
      Any help?
      -Justin
        WOW!!!! I thought I was the only one that had that problem installing my STB! I called up BMR and they said, "We've never had any V6 guy tell us this problem"
        OK, had the same problem. This is what you do: you need to actually BEND the metal A/C tube (BMR told me to do this). Just take your thumbs and push the line in towards the engine until the A/C sensor can clear. It will not damage the A/C unit, mine still works. Make sure you bend the tube, don't kink it.
        Bending the tube is HARD! It can be done, don't get discouraged. Do it with your hands; with a tool of some sort, you may **** up the line somehow.
        Good luck [img]smile.gif[/img]
        EDIT: And yes, I have the V6 bar, not the V8 one
        [ December 29, 2002: Message edited by: TheV6Bird ]</p>
        --<b>David</b>--<br /><a href=\"http://bryant2.bryant.edu/~dsantore/index.htm\" target=\"_blank\">The <b>NEW</b> V6Bird Website!</a> <br /><a href=\"http://members.cardomain.com/thev6bird\" target=\"_blank\">Cardomain site</a><br />ΔX
          Yeah just give it a slight bend. I have the same problem in mine.
          Here is a link to a pic of mine. Its the V6 stb.
          John -Acrophobic V6 racing-<br />\"Yeah, its a Z28, I just removed 1/4 of the engine to save weight.\"
            No problems with mine, but I have a 3.8 :D
            Thanks, <br />JAM<p>02 Firebird GT
              I just bent the line and it worked great! Took all of about 20 minutes. Sensor is back on and AC works just fine. [img]graemlins/fluffy.gif[/img]
              Thanks a lot V6Bird and SixVi6-Camaro for the info and the pic! [img]graemlins/thumbsup.gif[/img]
              edit: I love this board. :D
              -Justin
              [ December 30, 2002: Message edited by: jhkcam ]</p>
