Warped rotors maybe? - FirebirdV6.com/CamaroV6.com Message Board
  • Warped rotors maybe?
    When im going about 80, then i break real hard like from 80 to 40 or 80 to 0,
    I can feel that break pedal shake, and so does the car, but lightly. The steering wheel does not shake.
    What could this be?
    My car has GPS trackin\',traffic alert,its own phone #,PS2,screens. And What da H3ll,When I Turn da key it says \"You\'ve got mail\"..... <br />I swear and promise.. I\'ve had more cars then Charlie Thomas.. bounces in a Monte\' that hopped.. Pimped old skoo Blazer on Chopz, Today Its a Camaro at all da plya spots.
    Most likely brake rotors. Get em turned or get em changed.
    Should fix the problem.
    Not a problem, just a challenge...
      Could be rotors.
      However, if you have an ABS on your car, then what you could be feeling is the anti-lock system at work especially since you said you were braking hard.
      2001 Camaro M5 Coupe(1 of 2,737), no options, Whisper Lid, K&N Air Filter, Free Ram Air, MAFS Screen removed, SLP Manual Fan Switch, 160 thermo, DEE\'s T/B Spacer, EGR Block-off plate, IAT resistor, CAI to EGR air feed, B&M Ripper Shifter, SLP Replacement Grill, T/A Exhaust, SLP five spoke take-off wheels, BMR strut-tower brace, BMR Tunnel Brace, BMR 32/21 front & rear sway bars with poly, BMR Poly/Combo Rear Control Arms, Clear front & rear corners, HPP3 modified 87 Octane program.<p><a href=\"http://www.cardomain.com/id/red2k1\" target=\"_blank\">http://www.cardomain.com/id/red2k1</a>
        I don't think its your rotors, unless maybe its in the rear but if its stock then you have drums, if it was the front you would feel it bad in the steering wheel. It could be the wheel bearings, maybe a little air in the lines? You can pull a front wheel off and spin the rotor. If it hangs up they are warped and SHOUL BE REPLACED, if they turn ok all the way around they are ok, and you should look at other parts of the brake system.
        I have made a lot of money in my life, most of which I spent on cars and women.<p>The rest I have blown.
