Stefan, you might want to see about getting this guy as a sponcer (I mentioned I was on this msg board and he seemed interested). It's UMI Performance I found them on Ebay, but they are a sponcer on LS1tech.com. They have great customer service and fast shipping. I am pleased with the product as well as the price. Pictures are below.
I have always heard that you should install subframe connectors on a drive-on rack. This keeps the chassis/frame as it would be while the car is on the ground and eliminate and possibility that the frame was stressed or flexed in an abnormal way.
It probably wouldn't make any difference, but just thought it was a rule of thumb.
They definitely look good though!
Originally posted by viper98885: I have always heard that you should install subframe connectors on a drive-on rack. This keeps the chassis/frame as it would be while the car is on the ground and eliminate and possibility that the frame was stressed or flexed in an abnormal way.
I've heard and known friends that had problems with this. I hope it works out with you though.
-1999 Camaro Coupe 3800 Series II V6 A4 - SOLD<br />-1998 Pontiac Grand Prix GTP coupe
Looks good Patrick... if I were owner if the board I would look into them becoming a sponsor, however I don't know how sponsor driven this board is.
About the lift.... I do not see how it matters whether the suspension is loaded or not if you're welding it to the frame, the subframes will not move depending on the load on them. As long as the car is sitting level... it does not matter whether the suspension is loaded or not because it does not effect the position of the sub frames.
You can have problems created by doing it that way. You might not realize it, but your body does flex ALOT when lifted like that, hence the need for subframes in the first place. A local guy here with a big HP LS1 had HORRIBLE wheel hop and jarring issues when the exhaust shop did this the 1st time!
Originally posted by OneQuickV6: You can have problems created by doing it that way. You might not realize it, but your body does flex ALOT when lifted like that, hence the need for subframes in the first place. A local guy here with a big HP LS1 had HORRIBLE wheel hop and jarring issues when the exhaust shop did this the 1st time!
I have not been able to take her above 90 yet. I'll play with her some and see if it still feels good above 90. But as of right now everything seems nice and stiff.
Originally posted by HBHRACING: The idea is to install them, then load the suspention to tighten the LCA bolts. This prevents prelaod and binding
I'm not sure I fully understand what you mean? Are you saying they should have been installed the way mine were or not?
they should be attached anyway that is assy but assembled loose. then when you are done you should lower the car on the ground or suport the rear with stands and then tighten the LCA bolts. The same goes for subframes. They should be installed with a load on the chassis.
