LCA lube... - FirebirdV6.com/CamaroV6.com Message Board
LCA lube...
  • LCA lube...
    I just ordered Lakewood LCAs slightly used and wanted to know what the best grease to put on em would be. I've been told if I don't lube em up they will squeek like hell. BTW - I ordered some of aftermarket LCA bolts from Umiperformance to help. Just wanna get em installed right. Thanks.
    <b> \'95 Camaro 3.4L A4 <i>Rikku</i><br />AutoX - Drift - Street </b><br />\"Sideways is faster.\"
    I have lakewood LCA's also. They suck ***. Check to make sure the grease fittings are in properly, cause mine were a ***** and a half to get in.
    But other than that, i just used standard grease you put in a grease gun.
    i will tell you this: they do work well, i just didnt like the way the grease fittings fit in the friggin things.
      I used Bearing grease for the outside of the bushings to help them slide in and not sqweak. I used marine grade grease to inject inside the bushings via a grease gun. No sqweaks. Tighten the every living piss out of them... As hard as you can.
        all the while making sure you don't preload them. follow your directions...
          Not to be an *** but I wouldn't have posted had I received instructions. Thanks.
            probably uses it to whack off to his internet porn sites..haha..cheap shot..anyways..i use it on my car (only) ..theres still a tiny squeak..you can hardly notice it [img]smile.gif[/img]
