I can't get this over the black piece attached on the drivers side of the throttle body, before I go "customizing" this box I was wondering if there is a way around it or do I just have to manhandle it on.
You mean the brace is hitting the black box where the throttle cables hook up to the throttle body?
I bought one, did the same thing. Turned out it was a V8 STB... :mad:
1995 Camaro 3.4L A4<br />Check out my other ride. <a href=\"http://www.sounddomain.com/ride/820732\" target=\"_blank\">www.sounddomain.com/ride/820732</a>
hmm... I never had a problem other then the AC line, while installing it on my old car. But then again I too the cover off the throttle cable on my car.
