Anyone know the part number for the GM 1LE rear springs for the 98+'s. The part number in the tech Database isn't correct (or no longer valid)?
GM 1LE Springs
there are a bunch of different part numbers for FE4 springs the ones he listed are just one set, I belive that they varied by year.-Brad
2000 V-Star Custom 1100
:rock:
I gave you the ones that should be correct for your year model. These might not be made anymore. If they are still made, I would bet that the price has increased significantly since the production of the f-body ended. BTW, most people I've talked to think these spring are way too stiff for a daily driver.
by DoodlerHi, everyone. We bought a 97 base model convertible Camaro and someone broke the motor ... Lights were blinking on the dash and that someone ignored the...5 hours ago
by ssms5411Still trying to find oil leak on my Camaro, it’s a tough one. I think it is the oil pressure sender myself. Leaking when raving and going into boost....4 days ago
