GM 1LE Springs - FirebirdV6.com/CamaroV6.com Message Board
GM 1LE Springs
  • GM 1LE Springs
    Anyone know the part number for the GM 1LE rear springs for the 98+'s. The part number in the tech Database isn't correct (or no longer valid)?
    Front: 22132887
    Rear: 22132889
      No Parts Found on GMPartsDirect.com
        there are a bunch of different part numbers for FE4 springs the ones he listed are just one set, I belive that they varied by year.
        -Brad
        2000 V-Star Custom 1100
        :rock:
          I gave you the ones that should be correct for your year model. These might not be made anymore. If they are still made, I would bet that the price has increased significantly since the production of the f-body ended. BTW, most people I've talked to think these spring are way too stiff for a daily driver.
