Linear vs Progressive - FirebirdV6.com/CamaroV6.com Message Board
  • Linear vs Progressive
    As a result of my car getting keyed, the shop who is redoing my paint said they will give me some free lowering springs for coming to them and i dont know which i should get...
    I am debating between the Eibach Pro or Sport kit or going with a Linear rate spring from like Suspension Techniques (if they are still around and make a set for an 01') and wanted some advice.
    I am mainly doing it for the looks but i do want to go Road Racing sometime this year. To my understaning Linear rate are better for road racing but dont give as nice of a ride.
    Any help would be greatly appreciated.
    !! Drive it like you stole it !!<br /><br />I believe forgiving them is gods function, our job is to arrange the meeting <br /><br /> <a href=\"http://www.azclubgp.com/garage.php?mode=viewgarage&u=202\" target=\"_blank\">2002 GTP 40th Anniversary Edition Sedan</a> <br />-------------<br />Mods:<br />3.4\" Pulley<br />rigged K&N Filter<br />14.3 et
    The Eibach kit for 98+ V6 P/N 3870.240 is linear.
      Sorry WRONG
      Here are 3831.240, 93-97 V6 spring rates, the front is linear, and the rear is progressive:
      1" drop
      Front = 351 lbs/in
      Rear first = 80 - 137 lbs/in
      And the spring rates for the 3870.240, 98+ V6 kit, both front and rear are progressive springs:
      1.4" drop
      Front = 377 - 600 lb/in
      Rear = 80 - 137 lb/in
      Technical Support
      Eibach Springs, Inc.
      949-752-6700 x114
      Check out the other springs at:
      http://tech.firebirdv6.com/suspension.html
      Raven
        A-hem!
        http://www.camarov6.com/cgi-bin/ulti...c;f=2;t=002262
        In your own words Robert. But we are both right, because the rear is progessive, the front is not.
          the question was which is better for reg driving?
          is it that big of a performance diffrence between the two?
            A-hem!
            Good find!
            Raven
              Maybe update the tech d-base?
