does any body know what a good price would be to install a set of H&r's on my car i was quoted 180$ thats crazy
price for spring install
•)))2000 3.8L V6 FIREBIRD (Navy Blue) 5 speed <br />•Aluminum Alloy 3-piece custom built wheels - 17x10 (front)- 17x11.5 (rear) Tires:Front: 275/40-17 - Rear:315/35-17• Suspension Techniques 1 3/8 \" Solid front Sway Bar• H&R Springs • Koni revalved double adjustable shocks (front)• Bilstien Custom Revalved shocks (rear)• K&N •Magna Flow Dual Exaust• Stock wheels W/Hoosier Road Racing tires • Sound System•<br /><a href=\"http://www.cardomain.com/id/o0oskamo0o\" target=\"_blank\">•THE RIDE•</a>Tags: None
I was charged 200 for my 1LE springs. 60 for the rear (easy install I wish I did myself) and 140 for the fronts, which from what I hear are a real pain in the... [img]graemlins/crybaby.gif[/img]
later
carldev1996 Firebird Y87<br />Dark Green
Took me about two days to do the fronts, I wouldn't pay somebody to do something I know I could do.
SamAIM: escalier deverre<br />\'02 Pearl Blue Metallic RSX-S (daily driver)<br />\'98 Black Firebird<br />98 V6 turbocharged to 02 LS1 swap<br />\'02 LS1/4L60E<br />LS6 Block, LS6 Intake Manifold, Thunder Racing 215/220 .600/.523/115 Cam, Titanium Retainers, Crane Double Valve Springs, 125 shot NX Wet Kit w/ NOS brand Purge, True Dual \"H\" Pipe w/ two chambers and dumps, 17x11(rear) and 17x9.5(front) Black Powdercoated ZR1 Replicas on 315 and 275 BFGoodrich Comp T/A\'s (Street)/ET Drags/Skinnies on Weldlites(Track), 3.42/LSD
You can do the rears yourself.
The fronts require you to compress the springs to take them off the shocks. Its very time consuming, and, as we all know, time = money.~Derrick <a href=\"http://www.appstate.edu/~do54457/\" target=\"_blank\"><i>My Webpage</i></a><br /><b>\'96 3.8L V6 M5 Firebird Y87</b> | <b>162.8 RWHP</b> / <b>196.7 RWTQ</b> <br /><b>•</b> SLP CAI <b>•</b> <a href=\"http://tech.firebirdv6.com/y87.html\" target=\"_blank\"><b>Y87</b> Package</a> - 3.23s <b>•</b> 180º thermo w/ fan switch <b>•</b> TB spacer from DEE<br />1991 Jeep Cherokee Laredo 4x4
180 seems cheaper than what i've seen other people getting quoted. i paid a friend 100 to do mine. we got it done in just a few hours. the rears are pretty easy, you can do yourself. if you trust yourself to take apart the front i would do it on your own and rent a spring compressor or take the fronts to a shop. or else you can do the rears yourself and have someone else do the fronts.94 Firebird - Red A4<br /> <a href=\"http://members.cardomain.com/predatorbird\" target=\"_blank\">http://members.cardomain.com/predatorbird</a>
I got ripped off when I had mine installed. I bought them thinking I could do it myself, then had kindof a close call trying to compress the fronts and decided to take it somewhere to get it done. There are not really any good shops around here that I know of to take it, so I ended up going to the dealership, and it was about $350 including alignment. That was just the fronts, did the back myself.2000 Red Firebird W68
im going to do it with my freind and then take it to get aligned after
[ January 09, 2003: Message edited by: O0oSKAMo0O ]</p>•)))2000 3.8L V6 FIREBIRD (Navy Blue) 5 speed <br />•Aluminum Alloy 3-piece custom built wheels - 17x10 (front)- 17x11.5 (rear) Tires:Front: 275/40-17 - Rear:315/35-17• Suspension Techniques 1 3/8 \" Solid front Sway Bar• H&R Springs • Koni revalved double adjustable shocks (front)• Bilstien Custom Revalved shocks (rear)• K&N •Magna Flow Dual Exaust• Stock wheels W/Hoosier Road Racing tires • Sound System•<br /><a href=\"http://www.cardomain.com/id/o0oskamo0o\" target=\"_blank\">•THE RIDE•</a>
I did mine myself at my friends shop. Didnt use compressors, just let the front ones out slowly. It worked fine. It took us a little more then 2 hours. Granted I had it up on a lift. The fronts are the worst. 15 minutes for the rear. Good Luck!
~Josh~1992 Firebird 3.1<br />16.61@80.70<br />CCAI With K&N Filter<br />DynoMax Cat-Back Exhaust<br />KYBs Shocks and Struts<br />Hotchkis Performance Coils<br />Everything else stock for now!!!
