I"ve done a search and havn't been able to come up with any information on the suspension codes on my car. I have the F41 code which is on most V6 F-Body's, but the RPO"s for the computer secet suspension are different and don't match up with any that I can find in the tech database or the internet for that matter. They appear as the last for RPO's on my lable. Now I believe that the codes should be 6BP 7BP 8TJ 9TJ those are the codes for each wheel and should be on my lable? Instead I have 6PT 7PT 8TF 9TF Does anyone else have these, and could the also post their RPO's like these ones [img]smile.gif[/img]
Odd Suspension RPO's
1998 Firebird W68 Y87 A4<br />Raised Airbox<br />3\" Dynomax Ultra Flow CatBack<br />2800 Stall Torque Converter<br /><a href=\"http://www.tyler98w68.isask.ca\" target=\"_blank\">www.tyler98w68.isask.ca</a>Tags: None
Those are the RPO's from the springs ONLY.
PT are the front, and TF the rear. BP and TJ are similar.
GM spring tables are very complex with different p/n but all come down to just a few spring sizes.
PT=BP (45.5 N/mm, 257 lbs/in)
TF=TJ (19.9 N/mm, 114 lbs/in)Robert - owner www.FirebirdV6.com/CamaroV6.com
Raven
