suspension rebuild parts check... - FirebirdV6.com/CamaroV6.com Message Board
  • suspension rebuild parts check...
    Sad to say at this moment I can only really afford to do a little better than stock componets (no new sway bars etc.) My car does have 100K now, so i figure its about time for some new parts. Im going with poly graphite bushings for a little bit of an upgrade. Check out my list to see if im missing anything please...
    sway bar bushings/endlinks
    upper/lower ball joints
    control arm bushings upper lower
    wheel bearings (all 4)
    v8 takeoff decarbons (front and rear)
    what bushings will i need for the rear? And if i missed anything major up front PLEASE let me know. Id like to get everything thats really needed in on fail swoop. Im keeping my stock springs because i cant lower my RS here with these roads in Louisiana or Id be missing all my ground effects. Plus they got that 100K sag and that gives it a nice stance with no adverse affect on spring rate. Thanks alot!
    <a href=\"http://www.cardomain.com/id/y87inside\" target=\"_blank\">http://www.cardomain.com/id/y87inside</a>
    rear.. you shuld atleast replace lca bushings and the PHR's..
    torque arm is a good one to do also..
    tranny mounts another good one..
    [ December 02, 2003: Message edited by: AllTheGoodNamesAreGone ]
    [ December 02, 2003: Message edited by: AllTheGoodNamesAreGone ]</p>
      might want to have the tie rods checked out and the rack inspected as well.
