Yea, well.. My ABS light kept turning on, especially in the rain. When I was getting some engine work done, I also had the mechanic check the brakes. The left front speed sensor was replaced as well as the left front bearing. I drive around for a while, everything is fine. Today, I go down a hill, and brake.. The brakes seem to give, I hear a clattering noise coming from the left tire. A few blocks later, the ABS light goes on. I turn off the car, go down a hill again... same thing happens! Anyone have any idea what the hell they messed up before I pay them an unpleasent visit tomorrow?
brakes..
The clattering noise could be if they didn't install the shims, or didn't mount the caliper right.
You may also need to bleed the brakes. Did they remove the caliper (disconnect the brake line) when they changed the bearing? If they did, they may not have bled it properly, or at all.
If they fix the clattering noise, and you still get the ABS light, check the connector, sometimes they get loose, and start acting up.Wife and a dog, they both think they\'re Kujo.<br /> <br />1999 3.8 A4 Y87<br />Navy Blue Metallic<br />BFG G-Force KDWS 275/40/17s, <br />WS6 Wheels (17x9)<br />Phoenix Transmissions 2400 Stall Converter<br />FRA, Holley Powershot filter, Whisper Lid, Ported Throttlebody<br />2000 manifolds, Flowmaster, WS6 Tail Pipes, <br />MSD 8.5mm Wires, MSD Coils, Autolite plugs<br />Performance Cryogenics treated rotors<br />1LE Sway Bars and panhard rod, 1LE front springs w/SLP Bilsteins, stock rear springs w/ 3rd Gen Bilsteins, BMR STB, KBDD SFCs, 1LE rear lower control arms, 1LE front lower control arms<p>1968 Chevelle Malibu 327 TH350
by ssms5411About a week ago noticed my brake lights not working also Hazards not working. Installed new brake switch and still not working, checked fuses and what...3 days ago
