hey does anyone have the torque specs for the lower control arm bolts. (I have 1LE LCA's so stock specs should work).
I also need the specs for the sway bar end links. I have a popping noise in the rear and I want to retorque everything and try to eliminate it.
thanks
-Brad
2000 V-Star Custom 1100
:rock:
